Old 05-12-2011, 12:26 PM
Dangerous Doug's Avatar
Dangerous Doug Dangerous Doug is offline
Cobra Make, Engine: ERA 289 FIA #2108
First, check that it is properly grounded. The "-" should be connected to a good, solid ground, as well as the case.
I had one SW tach fail, and replaced it. I recently had a problem with the tach (again) but it seemed to be related to having managed to drain my battery---once I recharged the battery with my garage charger the tach worked fine.
DD
Dangerous Doug
"You're kidding, right?"
