Old 05-14-2011, 02:54 AM
Rob. Smith Rob. Smith is offline
Originally Posted by trularin View Post
Another common problem is blinker load. If you put LEDs in, they may not load the blinker correctly causing an assortment of problems.
Just a bit more.
Yep there's not enough current to heat the bi-metal strip in the flasher can...there's an electronic unit available now. Most mobs that supply the LED lamps supply the can.
