Old 05-16-2011, 07:59 AM
DonC's Avatar
DonC DonC is offline
Cobra Make, Engine: ERA #684, 428 FE, TKO600
Another vote for replacing the fittings. They shouldn't leak if properly made and applied. If you're getting fluid out of the fittings, given the amount of pressure a hydraulic system creates, it's unlikely that thread sealant will correct the problem. I'm well aware that getting to some of the fittings can be a real nightmare but bite the bullet. When it comes to hydraulics you really want it done correctly.
DonC
