Old 02-01-2002, 03:48 AM
Jack Zupan Jack Zupan is offline
I am updating this post because I would like some opinions on options. I pulled the heads from my engine and saw nothing that jumped out at me as being a problem. The head gaskets looked OK and the heads looked OK except that the bad cylinder looked oily. The only thing I noticed was in a certain light it looked like not all of the valves were at the same depth. Turns out this is correct. The machine shop has a list about $800 long of repairs that need to be done. One intake seat was shot, no inserts in the exhaust seats, guides are shot, wrong retainers, valves are multigroove, etc. Sounds like the guy who built the engine just slapped the heads on with no work. The funny thing is they looked good from the top, 7/16" studs, pushrod guides, Crane springs, CompCams roller rockers.
Anyway here's the question(s):Since I'm in for some big money anyway I have an opportunity to make some changes. I've already decided to pull the engine and re-cam it. With the heads I can go aftermarket aluminum but that would require new pistons, new intake, new headers and possibly new sidepipes. Probably too much money and a lot of hassles. I have a set of 4V heads I could install but that would require the same as above and without increasing displacement would probably not be a good choice. Finally I could also go with a set of Aussie heads. These have the advantage of the closed combustion chamber with the smaller 2V ports and should bolt right up. Compression ratio would have to be checked of course. There is a company that sells reworked Aussie heads for $1000 which may not be too bad if they use good quality valves and the machine work is good. I don't know how to tell that unfortunately. Has anyone out there had experience with PowerHeads? I might have found them from this forum but I'm not sure. Finally I could have my machine shop rework the heads I have. If I go that way are there any ideas on what one should do to the heads besides the required repairs to get more horsepower?
As always I look forward to what you all have to say.
Regards,
Jack Z.
