Old 05-18-2011, 05:20 AM
blykins blykins is offline
Default B2 Motorsports 369ci SBF Dart Short Blocks....
This would be a sweet little foundation for a 289 style Cobra build. Based on a Dart SHP 8.200" block, 4.155" bore, 3.400" stroke. Appearing externally as a 289-302 sized engine, but having the power potential of a larger Windsor.
Included:
*Dart SHP cast iron 302 block
*Fully machined/prepped
*Scat 9000 series 3.400" crankshaft
*Scat forged I-beam connecting rods
*Probe forged pistons, 20cc dish (10.25:1 with 60cc heads)
*Clevite main/rod bearings
*Mahle moly rings
*Ford Racing double roller timing chain
*Ford Racing cam thrust plate
*ARP camshaft fasteners
*Comp Cams or Bullet hydraulic roller camshaft
*Camshaft degreed/installed
*Rotating assembly internally balanced
*Short block fully assembled, balance & build sheet included
$4899
Other options available including a Scat forged crankshaft, solid roller camshaft, etc.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
