Old 05-18-2011, 08:53 AM
cdnus cdnus is offline
Cobra Make, Engine: 408w 500 h.p. 550 ft.lbs
Don't be cranking the engine unless you are sure you have oil pressure first.
Pull the distributor & use a drill with a oil pump drive shaft to check things first. That way there will be no further harm to engine.
Craig
