Old 05-19-2011, 04:27 AM
cbreez cbreez is offline
Most of the time an automatic transmission cooler line will not have the same pressures as elsewhere in the transmission. Many areas of the transmission have very little or no pressure ie: the sump which is where most cooler lines return to. I would say that you had a defective cooler. Earl's has been around a long time. It's not likely a faulty design.
