Old 05-19-2011, 09:12 AM
kitcarbp's Avatar
kitcarbp kitcarbp is offline
Cobra Make, Engine: West Coast, 460 Ford Racing Crate w/ TREMEC TKO 600
Default Re-Torquing 460 SCJ Aluminum Heads on the Ford Racing Crate engines
Its time to re-torque my 460 SCJ heads on my Ford Racing Crate engine after break-in and want to get feedback from those who have already been there done that. The set-up from Ford Racing uses ARP head studs and has adjustable rockers. SInce I have to remove the rockers to get to the head stud nuts, what tools work best for these valve lash adjustments after the head nut retorque is finished? I see LSM Tools sells a very nice big $$ valve lash torque wrench to make it fast and accurate. Other types have wrenches without the torque wrench built in.
I haven't adjusted valves since high school and need your input.
Is it best to completely lossen each ARP head nut one at a time (in proper the sequence) and re-torque to 135 ft-lbs (Ford Racing Spec).
Who has done this using Ford Racing motors with the Alum. SCJ heads ?
Thanks
"...some assembly required, ages 8 and up...... well that took longer than expected......
