Old 05-19-2011, 10:57 AM
kitcarbp's Avatar
kitcarbp kitcarbp is offline
Cobra Make, Engine: West Coast, 460 Ford Racing Crate w/ TREMEC TKO 600
Ok that helps me.
The adjustment method I see referenced by other builders is the one you mentioned (Adjust Intake when exhast begins to OPEN, Adjust Exhaust when intake is Almost closed, folks use EOIC a reminder).
But why not use the sequence of the firing order and adjust each cylinder when its firing @ TDC by starting at :
# 1, (adjust both I/E) then turn crank 90 deg,
#5, (adjust both I/E) then turn crank 90 deg
#4 etc. etc.
What are pros and cons ?
Does it depend on how much the cam is advanced in a given engine since 90 deg at crank may not put you exactly on cam lobe's base circle of a given cylinder ?
Does it comes down to being able to judge when the lifter is on the base circle of the cam ???
Thanks again
"...some assembly required, ages 8 and up...... well that took longer than expected......
