Old 05-19-2011, 11:37 AM
ItBites's Avatar
ItBites ItBites is offline
Cobra Make, Engine: Midstates, Vette suspension, Baer 6P brakes, 540 cid Chevy, Haltech Fuel Injection
No that is not the EOIC. That 90 degree rotate method MAY work with factory cams, but...
This is EIOC and is the only method that will never fail you, irrespective of camshaft lift, firing order, etc:
Set the intake valve when the exhaust valve on that cylinder is starting to open. EO = Exhaust is just Opening
Set the exhaust valve when the intake valve on that cylinder is starting to close. IC = Intake is just Closing.
Blykins already told you what method to use and now I have repeated it. Do not use another method, including the 90 degree method you have mentioned twice.
E. Wood
ItBites
10.69 @ 129.83mph - on pump gas and street tires
