Old 05-19-2011, 04:32 PM
BBQCYCLEWERKES BBQCYCLEWERKES is offline
Cobra Make, Engine: 2007 BDR FR Boss 302
Default Pleasant surprise while building OEM Cammer
Got my cammer block and internals back from the machine shop yesterday. Started to assemble the cammer motor and realized I have some special parts for this motor. I have one of the original protype/experimental front cam covers in my collection. It has a XE prefix casting/engineering number on the cover which referenced to 1 of the orig prototype covers. I placed it next to the other orig covers and noticed the diff casting/engineering prefix and the casting is slightly rougher and slightly different in some areas. I then went thru the different sets of cams I have and noticed a set that was etched with EONIX INC on the side while the others were either Crane Cams or OEM cams. I researched EONIX INC and found that they were a small company in Detroit that did experimental and protype cams for special applications. I then measured and degreed that cam and found it had almost the same identical specs and the OEM racing application cams. It appears this is a set of the orig prototype cams for the cammer motor. They were still wrapped up and sent by a person named Cecil Johnson. This cammer may be more unique and original then I had originally thought. If anyone has any info on the orig development of this motor I would appreciate it. I also found a gear drive system for the FE timing chain system I may use also. Any help or advise would be appreciated.
