Old 05-22-2011, 01:38 PM
DAVID GAGNARD's Avatar
Originally Posted by andronikos916 View Post
Hello guys. Thank you all for the replies and support. I will not order any parts until I contact the PE guys and get the correct parts with correct clearances etc.
About warranty the car has less than 900miles and the engine was build Dec 2009 (if I am not mistaken - I can double check that).
I am not sure if it is under warranty but I think this is another matter that I have to personally discuss with Eric.
Also I am not feeling confident to repair all that. I better ask for a professional mechanic to do the assembly once I figure all out etc.
I have problems since day 1 - I do not know what else to say. I can only wish for the best.
Andronikos,
Admitting your not confident in trying to do the repairs is a good thing,one must know when it is time to "step back" and let someone with more expirence handle the job....
If there is a mechanic that you trust in your area, it wouldn't hurt to let him check out things, I wouldn't let him do any repairs,only check out the engine,maybe a trained set of eyes could help identify the problem.....it is definetly in the valve train though..........
Since you've had problems from "day one", a qualified mechanic you trust looking it over would be a good thing right now......
Best of luck.
David
DAVID GAGNARD
