Old 05-23-2011, 11:46 AM
trg-42's Avatar
trg-42 trg-42 is offline
Cobra Make, Engine: Superformance MKIII
I use to use the Fram canister but now my favorite is the Canton CM filters
Canton Racing Products
I have it mounted upside down in the picture ( inlet is usually the bottom ) . The best part is you can remove the cover and change the filter without making a mess. When the filter is mounted the proper orientation ( unlike mine below ) you can lift the filter out without spilling a drop of gas
These have AN12 straight ports so you will need adapters
Its only about $60 so its inexpensive
