Old 05-23-2011, 01:21 PM
wemooz wemooz is offline
Cobra Make, Engine: ERA 290, 428CJ
Chas, do you have your carbs ganged so that both are always in sync and open to the same degree? It seems so from your photo. If so, I can guess that running them a bit lean is in order. But if I use the original type linkage, they will open in sequence and prior to the second carb opening, I would think that the first 600 CFM carb would be about correct. Am I thinking about this correctly? If ganging them is preferable, what are the advantages? Bill
