Thread: Sidepipe Bolts
Old 05-24-2011, 04:13 PM
greg schroeder's Avatar
greg schroeder greg schroeder is offline
Cobra Make, Engine: Superformance, Roush 427R-095, Pro Systems carb, 2" headers, Buckshot Racefab side pipes, 10s off idle start
The first problem I had was chunks of weld around the inside area of the headers and side pipes so they would leak and blow out gaskets. When I put a straight edge on either there were high spots. I fixed that and got new gaskets.
I used regular grade 8 bolts and these if I remember right.
but might have been these.
With the flat matching surfaces they never came loose. The bolts are used once and typically break when you take them off.
Never reuse the bolts even if they come off.
off idle drag pass, DA 750ft.
