Thread: Engine problem?
Old 05-25-2011, 07:15 PM
Barnsnake's Avatar
Barnsnake Barnsnake is offline
Cobra Make, Engine: LoneStar LS427 , 427 Windsor
Ideally, you should drain the fuel tank, flush the lines, clean the filters, and clean/rebuild the carburetor.
You might try removing the idle mixture needles and blowing compressed air through the passages. You might get lucky. I would fill it with fresh fuel in either case.
Jim
A Gnat! Quick, get a sledgehammer!
