Old 05-26-2011, 11:43 AM
redmt redmt is offline
Originally Posted by tcrist View Post
The only issue that I see is that the crack will continue to get longer. You have not stopped the crack, just covered up the surface.
JMO of course.
As Terry said! You need to drill each end of the crack to stop it otherwise it's going to continue to run with each heat cycle. No comment on the fix, whatever works temporarily but you have to stop the crack.
