Old 05-26-2011, 01:05 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by llwalkman View Post
I am running out of ideas here. Need some help please:
65 idles
150 mains
200 air
Idle screw 1 turn out.
Idle jet holder 1.00
Cylinders 1, 3, 5, 6, 7 spark plugs are light grey
Cylinders 2, 4, 8 spark plugs are sooted black.
AFR reads at cruise ranges from 13.1- 18.5
AFR on acceleration ranges from 10.9 to 13.1
AFR at idle is 25.0 to 38.0
I know I am running lean but cannot figure out why the trailing barrel of the weber carb is running rich. Any ideas? Thanks
Something doesn't add up here.
Where have you got your Lambda sensor mounted?
The engine could not idle on A/F ratios of 25 - 38:1.
So the whole lot of A/F ratios could be richer than you think.
Gary
