Old 05-27-2011, 09:52 AM
Cobra #3170 Cobra #3170 is offline
Default F.A.S.T. timing
Originally Posted by Stephan427SC View Post
Hi guys,
can anyone help me ? : I installed a 8stack-efi system with a FAST XFI ECU.
I decided to go the 50° BTDC route and installed all things this way...now after starting the engine, the engine idles at about 1150 rpm. I checked the timing with a timing-light and the timing shows 50° on engine.
Now I connected my pc with the C-com software from FAST. Here the "Spark BTDC" shows about 26° timing. The recommended timing for my engine is 16°@ idle of 900rpm.
Question : how should or can I set the correct timing of 16° at 900 rpm ? Turning the distributor until the programm shows the 16°...?
Thanks,
Stephan
I have an earlier system from FAST that uses crank fire. We set the pick up at 50 D. BTDC so that the system can then fire the plugs at the correct timing point dictated by the timing map. You can use another point say 47D.,
but you have to enter that number in the FAST software so the system knows the point to start calculating from. I actually had a problem because the dyno system program and the car pick up were different and I ended up with an overall retard of the timing map of 6D. at the Optima in 2009. When I corrected it by entering the correct location of the pickup in degrees the car spun the tires so much it was harder to drive. I think the fast system needs to have the mechanical position of your number 1 pulse in degrees entered into the fast software, you don't set it running with a timing light. You can check it vs the timing map later with a light but you need to enter the correct reference point first. PS make sure your distributor advance is locked out!
