Old 05-28-2011, 08:33 AM
Grubby's Avatar
Grubby Grubby is offline
Cobra Make, Engine: ERA 838
Begins at chassis #
CHANGE
6 Wiring harness design finalized
50 Aluminum floors replace steel
70 Subaru steering gear replaces Nissan
92 ERA tubular subframe replaces XKE sheet-metal one
150 Footboxes lengthened for extra leg room
220 Tilton master cylinders replace ATE brand *
265 Bulkhead behind seats moved, exposing the roll bar lower legs
350 Front X member between front suspension towers changed from square to round tubing
565 All chassis have mounting points for ERA rear suspension
600 Aluminum radiator instead of brass, using original style top and bottom mounts and shrouding
650 Wiring harness improvements for easier installation
731 Major improvements to body, inner panels and chassis
758 Steering gear and mounting system changed
* Recommended update
Taken from the ERA web site. There is a wealth of information there.
John
