05-28-2011, 10:30 AM
NH
That set up looks like Jag style where they use the axle as an upper arm. The Watts link set up is good for the forward/rear bracing. The original style has an upper and lower arm that are both independantly braced but that does require an axle(half shaft) that changes length through suspension travel. The half shafts are so short it's basically a couple of splined yokes put together.
