Old 05-28-2011, 02:47 PM
mdross1's Avatar
mdross1 mdross1 is offline
Originally Posted by joyridin' View Post
The 315's won't fit with the upper spring mounts. You also need tube-style lower control arms with no coil spring mounting on them. I narrowed an 8.8 style rear 2.5" on each side to give it the deep dish look. It is tight, but worth the effort.
Had a 9" narrowed to get the correct offset and using 295/50X15".Also had Chromemoly tubular control arms built top and bottom for the adustability,Using coilovers all corners,also had car scaled now it drives like it is on rails.
