Old 05-31-2011, 01:56 PM
CobraDan's Avatar
CobraDan CobraDan is offline
A soft top or a hard top give basically the same look but a soft top can be stored in the trunk & the hard top or lemans can not. As far as a passenger is concerned no top will make you more or less comfortable inside the car. They all leak but getting out of the sun or 90% of the rain is nice once in awhile. If you want the trunk to work with a Lemans top you need to change the trunk but since tops are normally made to be removable you could remove the top to get into a normal style trunk.
Dan Wulff
