Thread: Solar Panels
Old 05-31-2011, 05:32 PM
Mulv's Avatar
Mulv Mulv is offline
Cobra Make, Engine: Cobra-less for now..
All solar panels put out about 40 watts, the efficiency is in the control and connections. What is little known to the consumer is that if one of the cheaper panels fails, your whole grid is down as they are series connected like the old xmas lights. You will need a lot of panels to run your house under peak load, way more than you can fit on your roof for sure.
The savings come from the reverse power that you make when you are not home and there is low load. Basically you make credits that you can use when you light everything up between 6pm and midnight. So if you are home all of the time watching TV and microwaving popcorn you will save some money but not as much as if you have a vacant house during the day. Also be aware that no solar panel makes 100% of its rated juice as the sun is on an oblique angle . Any dirt - like dust - lowers the efficiency as well by a surprising amount - I have the numbers somewhere so you need to clean them a lot here in the valley. I am working on an automated gizmo to take care of that on commercial panel farms.
I used to have a solar panel biz in silicon valley and my current partner in a start-up makes the connecting chips to balance the load and allow for parallel connection so I have a bit of insight into the production end, others could speak of their home benefits.
Everyone who is a serious player avoids the residiential market at all cost - impossible expectations , potential for damage during install and liabilities later. Anyone in the residential end of things makes a lot of "statements". Be sure to talk to APS for a reccomended installer.
If you completely covered the roof of a huge shopping mall with panels you might generate 40% of their needs. The only way to make solar in a practical way is on a farm of about 100 square miles. That would make enough juice to power the western half of the US into the next century. The problem is the NIMBY clause that we see occuring in the central valley of California right now...
It's under a big W, a big W see?
