Old 06-01-2011, 02:26 PM
BBQCYCLEWERKES BBQCYCLEWERKES is offline
Cobra Make, Engine: 2007 BDR FR Boss 302
Default Repairable/Rebuildable FE parts for sale
Finally getting to inventory & sell some of my deceased friends FE parts. I have 3 427 center oiler blocks with a blow hole in the lower skirt. Repairable by welding in a replacement window in the blown area. no damage to the webbing. I'll supply a pre-fit window replacement piece for the block. $400 each. 1 427 center oiler with no hole: $550.00. 1 427 center oiler with no hole. Decked too much on 1 side per machine shop: $375.00. Poss candidate for a shorter stroker kit? 1 427 side oiler with a repaired hole in the skirt. Machine shop checked block. all ok. $1350.00. 1 406 block. No visable damage. $700.00. I have 3 cast 427 cranks that have badly spun bearing. All will repair per machine shop: $150 each. 2 428 CJ cranks with spun bearing that will also repair: $150 each. 3 set of 427 rods with the 13/32 rod bolts: $200 set. 1 set Mickey Thompson Alum 427 Rods: $300. I have 5 Mickey Thompson Alum Rods with SOHC pistons attached: $90 each. Approx 8 damaged SOHC pistons: $45 each. Blown 427 side oiler Rod & pistons: $40 each. 427 SOHC blown rod & pistons: $65 each. Lots of heads, Alumn 4V manifolds, etc I'll list later. Message me if you need something. I'll list the complete SOHC motors fairly soon also. Bob Q.
