Old 06-03-2011, 11:35 PM
Michael C Henry Michael C Henry is offline
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
If there is a loose conection I haven't found it yet. When it was acting up , I left the ignition turned on with the dimm indicator lamp lit and didn't see it flicker get bright or anything else when I tested the battery, ground, and master switch connections. I even had the fuel pump turned off so I might be able to hear a click of a solinoid if I did cause anything to change.
Mike H
