Old 06-04-2011, 06:27 AM
jhv48 jhv48 is offline
Fire up the engine and pull the plug wire from each of the offending plugs one at a time. Hold the plug boot next to the block and look for a spark to jump. Or you can just touch the end of the boot with your finger. (when you wake up, proceed to the next plug and see if there is a spark to it as well).
If there is spark to both plugs, and I bet there is, then you have a fuel delivery problem. Go back to the carbs. Could be the same problem to two separate carbs.
Jim
