Old 06-04-2011, 07:26 AM
bobcowan's Avatar
bobcowan bobcowan is offline
What do you mean by, "Hard to start"? If the engine turns over like it usully does but won't fire, then it probably is hot fuel. Use a infrared thermometer on the carb bowl and see what you get.
But if it's slow to turn over, then it's probably an electrical issue. Like a hot starter or battery cables that are too small.
For a hot fuel issue, there's a couple of fairly simple answers. For the carb, I would use a heat shield like this one Holley 108-70 - Holley Carburetor Heat Shield - Overview - SummitRacing.com I would start without a phenolic spacer and see how it goes. If it was still too hot I would add a phenolic spacer.
There are a number of heat shields available for the fuel line. Inexpensive and easy to apply.
If it's really bad, consider adding a return line.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
