Old 06-04-2011, 10:50 AM
Danielg Danielg is offline
Engine timing is critical with all Demon carbs. They do not work at your typical 12 deg advance. They must see a minimum 18deg to function, they require that much.
I have them on two cars and love them, I hated them at first because they hesitated etc. I locked out the timing full advance using a start retard msd for easy cranking. works flawles and the engine response is crazy.
Unfortunatly when people buy demons no one tells them about the 18-22 deg they need, I also was not informed, or I would have bought something else. but I end up messing with them and couldn't figure it out and a sharp tech a BG told me about the timing. Problem solved.
Daniel
