Old 06-06-2011, 03:11 AM
Default Did you allow the system to drain?
trg-42 If you didn-t cap off the slave cylinder when working on the clutch, you are air bound. The other issue could be no pressure from the master cylinder. Seal went bad from air getting to them.
Start with unhooking the line to the TOB and get a quart bottle (clear) for a caught can. This line needs to be in the fluid. If the fluid looks clear and not cloudy you can reuse it. Bleed out the master first with pumping it until you get all the air out of the master. Once this is done . rehook the TOB back up. You need to be able to push in the bearing after "EACH" Pump of the pedal. You need to press and hold the pedal down, crack the line in a bottle of fluid. tighten bleeder and release pedal. If this doesn't work, crack the bleeder and press the pedal and hold it with the bleeder open. Close bleeder and release pedal . repeat until you have fluid coming out. If you release pedal without tightening bleeder you will either pull fluid back into the system or air. Fluid is OK, air no good. It this time try and push in the TOB. You will need to do this until you see on bubbles coming out of the TOB bleeder.
If you have a Phoneix bleeder kit, $300.00 they work good too but need to partially press pedal to get fluid to go through TOB and back into master cylinder. DON'T let TOB get over extended when bleeding.
