Old 06-06-2011, 12:18 PM
elmariachi elmariachi is offline
Your engine and cooling system both sound okay, it just sounds like the cooling system lacks the capacity at idle to cool the coolant. The value of a fan shroud as mentioned by FWD is enormous, don't discount it. I would suggest you get a $60 infrared temp gun like this Micro Temp MT-PRO - Spark Industries Micro Temp Digital Infrared Pyrometers - Overview - SummitRacing.com and check your upper and lower radiator temps and check temps in the path of the fan and then outside the fan path. If you don't see 30-40 degree reductions from the entry and exit point if your radiator, your fan/shroud isn't doing the job. And if the temps outside the fan path are considerably higher, then the shroud or lack thereof is likely a contributing factor.
As for pulley size and pump circulation, I wouldn't go there yet. If you start trying to circulate the water faster, you lesses the amount of time it sits in the radiator to be cooled.
