Old 06-07-2011, 05:36 PM
BDR879 BDR879 is offline
Cobra Make, Engine: Backdraft 879, Indigo Blue / Wimbledon White, 428 Cobrajet, TKO 500
Originally Posted by Dinobyte View Post
I recommend a fuel return line...
I run both a mechanical and electric pump.
When I added the fuel return line, it worked like a charm and solved the same issues you are having.
Dino,
I'm working through the same issue on my BDR and this option is the next on the table. A couple of Q's for you:
- Does your return line loop back from the carb back to the tank (long loop) or is it routed from the outlet of the elect pump back to the tank((short loop)?
- What elect pump did you use?
- Does the elect pump flow through the mech. pump?
Thanks
