Old 06-08-2011, 05:12 PM
BDR879 BDR879 is offline
Cobra Make, Engine: Backdraft 879, Indigo Blue / Wimbledon White, 428 Cobrajet, TKO 500
Sounds like great progress. Sounds like your engine temps are solid and in the proper range from what I can gather from other FE owners.
Next week my car is going in for:
1) dyno tune and proper carb setup. Apparently if the system is running lean, the engine will run hot. The car had never been tuned and it will be worth the $300 to see if that's compounding my issue.
2) 1/2" phenolic spacer installation
3) Re-plumbing the fuel line from the firewall to the carb with braided hose (currently have tubing) and covering it with heat shielding where applicable.
If the above does not work, I will go the electric pump and recirc to the tank route similar to Dinobyte's.
Good luck and keep up posted
