Old 06-10-2011, 04:47 AM
blykins blykins is offline
With no drain hole, you either have to pull the center section away from the housing, or if you're creative, you can jack the rear of the car way up high and just pull the pinion housing off the front. Magnets are always good.
For break-in, I always advise customers to take a couple of 5-10 mile easy drives and let the rearend cool down in between each one. After that, put about a 100 miles on it at one time. Then you should be good to rock and roll.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
