Old 06-11-2011, 10:54 PM
COBRANIP COBRANIP is offline
Cobra Make, Engine: VSE alum. frame, FFR carbonfiber body (under construction)
Is there enough material on the flange that you (or a machine shop) could grind the high side down? If not the low side could be built up with a bead of weld and then ground down.
Just my 25 cents worth (have to allow for inflation, you know).
