Although you already have it out, one possibility would have been to pull the spark plug on #3, used a leakdown tester to pressurize the cylinder while the intake valve was opening. Could have blown it back up the runner. Another possibility would have been gum on the end of a long screwdriver.
Something to try "next time"
Glad to hear the build is coming along well.
Originally Posted by RestoCreations
Just thought i would report that the car is almost finished. I suffered a small set back when i dropped a piece of plastic down the intake last week. I used a 1/4" thick carb gasket from edelbrock, which has plastic reinforcements around the stud holes, and one popped out and rolled down the #3 intake runner. I tried everything to get it out, but after 4 hours i finally threw in the towel and pulled the intake. So, i am just waiting on new custom gaskets from cometic and then i will reassemble the intake. First start should happen next week.
