Thread: It's Alive!!
  #23 (permalink)
Old 06-13-2011, 06:10 PM
BDR879 BDR879 is offline
Cobra Make, Engine: Backdraft 879, Indigo Blue / Wimbledon White, 428 Cobrajet, TKO 500
Originally Posted by lovehamr View Post
879, thanks for the heads up on the gauge calibration but I got nuthin’ there. It must make intermittent contact because I have 3 miles on it now. Any hints on where I might find both the fuel and speedo problem in the harness?.
Once I got the wiring spool piece at the diff installed and connected it to the end of the harness, I ran the car around and the speedo would come on intermittently. The issue wound up being the quick connect connection...although it appeared that the connections were solid, it apparently was not. We ended up hardwiring it and it works fine now. There is not alot of extra slack in the harness wire, so make sure you only cut/strip once I have no ideas on the fuel gauge, but I would check the quick connects at the fuel tank to the harness....it could be the same issue.
I also also have the diff joints leaking a bit...still happening after a year. I just tighten them up from time to time. All bolts appear tight, but still get the drip. I guess its just par for the course
