Old 06-15-2011, 09:28 AM
951mat's Avatar
951mat 951mat is offline
Cobra Make, Engine: Lonestar, 427 Center Oiler
Thanks for all the replys. I did find my dyno sheets and that showed 32 degrees timing for max power, not 28 like I thought. I advanced to 32 with little to no change. I never have believed my laser temp gun, but threw that out there anyway. I did put my temp sender in a coffee cup of hot water with a thermometer and it seems to be fairly accurate. I did boil the thermostat and it opened as advertised at ~180. I pulled 2 plugs that look good (not lean) but will look at others. Will keep you posted.
