Old 06-15-2011, 02:14 PM
treblig treblig is offline
Cobra Make, Engine: Midstates in-work again
Originally Posted by tt400 View Post
I am putting to gether my cobra with a 9" rear axle and coilover suspension. The rear axle is 1/2" offset farther to the passenger side of the car. I also measured the distance between the front spindles and the center of the rear axles. It is 1/2 shorter on the passenger side. Is this correct? Am I doing something wrong here?
Thanks
If your measuring the center of the pinion to the center of the frame that is wrong. The pinion should be .500 off center to the out put shaft on the trany on the passager side.
In order for the u-joints to work properly, your pinion needs to be offset and your angle of your pinion and trany needs to equal 180 degrees.
Treblig
