Old 06-15-2011, 05:29 PM
Dan Case's Avatar
Dan Case Dan Case is offline
Original Shelby Owner
There are two large harness sections plus
- a harness for the fan in front of the radiator, connects Ford ends to Lucas ends.
- a harness for each head lamp, Ford to Lucas adpaters in affect as above
- a harness for each front turn signal, Ford to Lucas as above
- a harness for each tail lamp, Ford to Lucas as above
- a harness for the SW XF- tachometer and XF- tachometer sender
- a harness for the tag lamp which is also a Ford to Lucas adapter
The diameters and lock in features of the Ford and Lucas "bullet" connectors don't match. I learned the hard way that buying Fairlane harnesses, loose wires, Lucas male and female connectors, and part of a big Ford harness for the 1963 alternator plug wasn't going to be acceptable to fix my red car. Yep, bought all that stuff. Hated to toss most of that stuff but since I was trying to get away from wiring problems I let the professionals make harnesses.
Dan Case
