  #36 (permalink)
Old 06-17-2011, 03:18 AM
Default Mat Talk to CH when you get a chance
951mat I heard that you changed the radiator angle in the car?? Any truth to this?? If you did put it back to a 15-40 degree angle, here is another problem, Air doesn't like to bent. At highway speeds over 40 mph the fans do nothing to help get more air through the radiator. enought air will cool the motor and raditor because of speed. Just like Nascar.
The debate goes on about which raditor does more to remove the heat from the water/coolant as it passes through.
Either way If it's simple, put the rad back to up and down if you can and retest. If you can't do this, you need to add a splitter in the opening to bend the air so that it helps cooling. Have a save trip. Rick L.
