Old 06-17-2011, 07:59 AM
wrogers55's Avatar
wrogers55 wrogers55 is offline
Cobra Make, Engine: Backdraft #318, 418 CI, 532 RWHP, Mass Flow Injected, TKO600-Road Race, BMW M3 Suspension, Race Springs (Wouldn't do it again, rough on the street).
Just to get everything possible on the table:
Intake leak causing motor to go lean under acceleration might be a possibility.
Might check for higher than expected oil consumption (not sure your motor is susceptible to this so others might have good info). If the motor can suck oil, it will cause hot spots as well and really make a noise under almost any kind of acceleration. You should see a bit of smoke on early acceleration on the side leaking (again, if that motor is susceptible to internal intake leaks).
Does sound like the knock sensor though doesn't it.
Good luck.
Wayne Rogers in Hideaway, Texas
