Old 06-19-2011, 08:55 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
I've generally been staying out off carb tuning discussions because generally the poster doesn't want to listen but seems like you guys are carrying on in a dedicated civil manner so here goes a few guide lines---
A couple items about the demon---they have pink accelerator pump cams and should be around a 31 squirters---this works pretty good for a starting point.
They all seem to have too high a power valve and I will generally drop to a new 4.5 or 5.5 and sometimes on a BIG cam maybe a 3.5.
Jets, a general Jerry rule is sizes of Holley jets that = stated cfm of carb---800 cfm carb, #80 jets----I would probably do 78 pri and 82-83 sec for a start--primary has pv which = 3 -5 jet sizes
Demon carbs---there was a period of time where they were full of chips---this era probably turned more tuners away from these carbs and killed the company
Idle-eze---if you have an aircleaner stud that is 5/16 thread, you probably have an idle eze base plate---remove the stud and with a slender screw driver you can adjust an air valve that is located in the middle of the base plate---this allows you to keep the butterflies where they need to be over the transfer slots---Oh did I mention that the transfer slots usually have a burr inside the drilled hole?
Try to identify the carb number and if it has an Idle eze base plate----
