Old 06-22-2011, 03:12 PM
strictlypersonl strictlypersonl is offline
Bobcat,
Do the frequency calculations first. You'll find that the car is initially set up with a pretty strong difference between the front and rear (by design). I recommend that the springs be changed rather than the anti-sway bar so that the lift under acceleration is reduced, and therefore reduced camber change. This will decrease the amount of power-on understeer/lift-induced oversteer you get.
