Thread: Steering Play
Old 06-28-2011, 10:45 AM
strictlypersonl strictlypersonl is offline
If your car is using a Triumph column (fairly unusual), there is a center bolt in the clamp that can can adjust the tightness of the joint.
With the ERA column, check for wear on the flatted shaft and on the clamping plate. You might be able to compensate for wear by flipping the plate the other way.
