Old 06-28-2011, 02:18 PM
Z-linkCobra's Avatar
Z-linkCobra Z-linkCobra is offline
Cobra Make, Engine: Everett Morrison, All aluminum small block ford.
There is the option of doing a wetsump external. you can run the shorter clearance pan and still get the pump outside of the engine. Then its just a single stage pump, no tank simple lines. You get the added 20 to 30 hp, the constant supply, adjustable pressure all the benefits while eliminating alot of the headaches. We had setup like that on our supercomp dragster...worked well. Just food for thought.
Gene
" If it wont break em loose in 3rd gear, it aint enough power "
