Old 06-29-2011, 05:31 AM
mln385's Avatar
mln385 mln385 is offline
Cobra Make, Engine: BDR
If a Radiator is properly sized for temperature it is exposed to you will maintaine the apropriate temperature via the thermostat opening and closing.
If you are running hot on the higher outside ambient but not during the lower your radiator is running at or beyond it's parameters.
My issue would be once the radiator was heat soaked it would exacperate the issue.
Good luck which ever avenue you decide to take.
