  #22 (permalink)
Old 06-29-2011, 11:59 AM
SoTxButler's Avatar
SoTxButler SoTxButler is offline
Cobra Make, Engine: Butler...488" hi-rise, dry-sump FE s/o w/stacks
Just Dreamin
Don't know which V10 you are talking about, but if it is a Viper, there are some pans available. Check Dry Sump Oil Pumps.
They also manufacture a dry sump pan for the FE motor. And, with their setup, you avoid all the lines from the pan to the pump. The pump is mounted on a manifold that scavenges directly from the pan...no hoses. The only hoses are from the tank and the pressure side to the motor. There are some pics in my photos that show the setup.
Good Luck
Russ
