Old 06-30-2011, 07:53 PM
Jeff Frigo's Avatar
Jeff Frigo Jeff Frigo is offline
Cobra Make, Engine: ERA 454 S.O.
Are you running all mechanical advance or do you have a vacuum advance distributor? It sounds somewhat like an over-advanced condition I had with my BB Corvette motor with a vacuum advance distributor.
A bad plug wire is another possibility. Seems they show up more under light load and idle than any other time.
No vacc. advance. All of the plug wire are from 120 to 130 ohm resistance.
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
