Old 07-02-2011, 04:16 AM
vettestr's Avatar
vettestr vettestr is offline
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
Stumble or miss only at cruise or light throttle >>
I bet this is a lean condition stumble. I would ask for all the basic/normal stuff to be checked .... float level, manifold vac. OK or no leak, timing at this RPM?, total timing.
Will it clear up if you add a bit more throttle ? It's a hot rod so add more timing and fatten her up a little more, increase RPM or get on the smooth side of the cam. Drive faster !!!
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
